I created this Army sign in F360. I cut it for the first time late yesterday. There are some single line arrow shafts that generated lead-ins even though I have that unchecked when creating tool path. The arrow shafts are the only single lines and are a separate tool path from the rest of the body.
They showed up in the cut exactly as shown in the CAD image below. I can’t seem to eliminate them. Any ideas?
Fusion’s weird “pierce clearance” setting seems to be a holdover from machining, where you want to start your cut with the tool far enough away to prevent a crash. It’s completely unnecessary for plasma cutting operations, in my opinion.
Hey sorry been up skiing. It think @ds690 is probably right. I found out the same way you did. Checked off leads expecting to have the pierce in-line with the cut. When that didn’t happen i scratched my head and tried setting pierce clearance to 0. It worked and I never thought to ask why. So we both learned something from your question.
Mine is doing the same thing despite setting pierce clearance to 0 and turning off lead ins and outs. Any suggestions what to do? @72Pony@ds690
edit: ah nvm i got it to go away by checking the lead in boxes and just setting everything to 0, including pierce clearance. that one was a head scratcher for a while
