Ok so I’m having an issue creating G-code from sheetcam . here are my 3 options . I’ve tried all 3 and the same message pops up on fire control . I’m not sure what I’m missing or where to change the values it’s telling me to change .
Choose the first one… also, have you created a toolset for the specific gauge of steal your cutting?
I’ll try it again and yes I thought I did but I’ll double check that tomorrow first thung as well . Thank you !!
You either don’t have a Sheetcam license installed or you don’t have a cut speed in your tool. The speed is commented in the last line of the program and the demo version is limited to 180 lines of code, so the last line usually gets cut off on anything larger than a small bracket.
Ok guys so as usual it was just me being a dumbass !! Turns out I forgot to set a tool path for the program !! Thanks for the help as always !!
