I have seen lots of people asking for files for one so I modeled one up that should be easy to build and uses a hinge off Amazon. It does however require welding.
Who wants to be a guinea pig and let me know what needs adjusted?
I don’t have my table yet or I would cut a prototype myself.
For now I will not post this on Fireshare until we know it works well. I will pm the files to whoever wants to test it out.
Mikal_M and fredycruger have the files and are going to test out the prototype for us. After any necessary adjustments I will post this up on Fireshare for everyone. Thanks to those two for being a guinea pig for us!
For those poor souls that dont own a welder I will work on a complete bolt together solution soon!
I would like to try cutting and welding the stand you made. Is there a way you can email me the file. murraysmetalworks@gmail.com. Thanks for your work.
both sets of bolt holes I had to drill out to make bolts go thru… not sure if it was on my end but no biggie… and I made my own hinge from 2 pieces of 3/8" ID 1/2" OD x 3-1/2" hollow stock and 1 piece of 3/8" OD x 2-1/2" solid steel stock…
did the other guy ever get his cut? and welded together? also if you can figure out a way to make a bolt together kit ill cut and try it as well. I have plenty of steel stock. I work for a guy who owns a scrap yard and I get all the metal I need. all of our local welding shops take their drops and scrap steel to him and I get to pick thru it.
Can you add 2 cutouts to the top plate near where the laptop screen folds down to run a strap thru to hold computer on stand? So it couldnt get knocked off.
