Langmuir controller board
I was looking at the wiring for this and i’m confused by how the board is wired up? i’d like to get step direction and enable connections from this but am nit able to make sense of what’s there now , that obviously works. anyone have a diagram or explanation?
Aside from the main board and THC being proprietary, everything else is pretty simple.
You have the board which receives power and signal, with another portion of the board putting out signal to each set of drivers.
Each driver receives signal and power.
Are you attempting to trouble shoot something? There are a number of members here that are very knowledgeable that may be able to help if you have a specific question.
The box is really a mess of tie wire lol…I see the way the drivers are wired but don’t understand the Pulse wire I think it has a common negative with another circuit and I need a source for the enable ± which aren’t used with the drivers
Sounds like some reverse engineering going on.
The drivers are enabled by default so CrossFire doesn’t use them or provide a signal for them.
Yup i made a new circuit for enable and wired through an e stop loop
