Hello, I read that the Razorweld Nozel is .1 kerf should I be using .1 instead of .06 kerf that I have been using in sheet cam?
.055-.06 " kerf width is normally for many plasma cutters.
best practice is to do a kerf test for the specific scenario you are working with.
there are several topics on determining your kerf width so you can search that above.
Where did you read this ? .1 is a huge kerf width
The nozzle size is 1mm, which is roughly .040".
