I’m making a mess every time i finish cutting. The air on my thermal dynamics cut master 58 keeps going for about 5 seconds after it stops cutting. During this time it splashes water all over. Shop floor gets real wet.
I’m using fusion and I’m just a beginner. I have learnt a lot in the last few weeks but have miles to go. I will have to watch videos to figure out how to set my park position.
If you know g-code, even if you are only a little bit familiar you can open your .nc or .tap file with Note pad or a similar program , scroll all the way down to the last G00 line just before M30. The G-code line will be G0 Z 1. or what you set usually? Change this to G0 Z 2. press enter and then add X ___ Y___ to where you know that the torch will be setting over solid material. When you change the Z position make sure that there is clearance for the amount of Z lift that you want. SAVE your changes. If you are away from the machine when it finishes it will move to your preset location and then stop. Hope this helps.
You might consider increasing your post flow on your cutter beyond 5 seconds. I know it is currently making a mess with the water table, but the post flow is extremely important to consumable life. Best of luck.
That is what I do, I use a piece of lexan. If I’m at the edge of the table I’ll put it there to stop splashing then when it is done I’ll fire it under the torch head when it is cooling.
You can’t with some plasma cutters, it’s set internally and not meant to be adjustable. Others have a knob on the front to adjust it. There it’s intuitively obvious.
I ran a 10 torch machine with no water. My point is very thin metal would warp and you lift the torch over the warp. I hate the water tub, my son swears by it. I think water tubs bring a lot of money to a CNC plasma company. As for breathing fumes that’s what what you get when you put these machines in a small garage. When my boy hand plasma cuts a 34 inch line I ask him wheres the WATER, you want to kill us. Joking of course I hope you get my point
I made a flat piece of metal with a handle on it . When torch is done cutting I slide it under it. Works great !! Had same thing happen with both my plasma cutters… Razor 45 and Hypertherm 45
