I’m just trying out the CAM side, new to that. Set up the cutter and parameters with the tutorial, (one day when I get good I’ll do one for MACs). The simulated cutter only does the one cut but will not do the four .250 holes. I had them selected all five cuts had the red arrows. Hopefully there is a screenshot attached to show the error I’m now getting.
When making a cut path for something like this you can have more then one profile. So if you want to set it up so the holes cut out first with the smaller lead in then the next profile cut out the outside with different parameters with a larger lead in or whatever.
Just make sure you have setup highlighted on the drop down on the left so your gcode incledes both profiles.
