why does the cnc cut nice or kinda smooth edges on an external radius but they are jagged on internal radiuses and the machine stutters on doing them (internal radius)
I’m using fusion 360 and the design file is at the bottom of the pictures.
Hi TinWhispere, thanks for the link. I tried posting the file and it looks like it worked but I’m not sure.
the file is last under the pictures that I posted.
Is your picture above from the off cut of this project? If so you might not be aware that there is a good side and a bad side to the cut and the off cut will have the bad side so the results of the off cut are meaningless.
Yes, it is the cut off but i can see the same pattern on the good side. in fusion 360 there is a “tolerance” option, and it refers to how smooth is the curve (I think). but what im not sure is why does this happen only on inner radiuses.
