I’m trying to make multiple cutouts for the same drawing/pattern. The first cut perfectly matches the drawing, but after each progressive cut, the cutout begins to deviate from the original drawing. Lines become wobbly and cut-points worsen. I’m not sure what could be causing this issue. This has happened with several different patterns, so it is not limited to one file/drawing.
Probably consumable wear. What is the cut time per part?
Hi Trey,
Can you post pictures of your cuts?
Consumables were replaced before cutting started. here’s an example of the difference from first cut to the second cut. https://www.dropbox.com/s/hysb7hcoxkzrxe3/filet_compare%20-%201.jpg?dl=0
I will try to get more pics tomorrow.
