Does anybody have a diagram of how the vipercut 30 should look? My electrode is actually spring-loaded and presses against the tip, which then presses against the outer shield. I am new to the plasma cutter thing, but it doesn’t seem normal that the electrode would touch the outer tip. I think it basically turns the whole tip into an electrode, which seems bad.
There is a plastic swirl-ring that goes between the tip and electrode, but the electrode still touches the tip. Is this normal? Vipercut 30. Thanks!!!
