Is loop cut inches?
when You measure a part is your loop measurement your actually cut inches?
Loop measurement is a measurement of the 2-D geometry you have drawn for one continuous line. It does not take the entire cutting length into account because additional cutting length is added when you create your tool paths because of the lead in/out parts of the cut after the Plasma Cutter pierces the metal. The Lead In/Out can be controlled in one of the tabs available when you create a tool path. I’m not positive, but you might be able to find a total cut length when you simulate the cut in Fusion 360. Ill look into it more and follow up.
Thanks, maleybr helped me get this figured out on my other post. Inches cut can be found in simulation
