Is it possible to rotate the view of the table in FireControl?
I use an XR table (4 x 8) so the view on the screen is a vertical rectangle. I have the screen remote mounted, and I’d like to rotate the table view to horizontal with X0Y0 in the lower left.
Is this possible?
I’ve gotten mostly used to it, but sometimes it takes a wrong push to remember which direction is which when manual jogging
Did you try changing screen orientation in Windows settings? Control Panel, System, Display, Landscape.
Have you been able to figure his out? I am having the same issue and it would be much easier for me to navigate the x and y.
