Introducing the Valley Oak Customs Design Manager (Private Preview)
:hammer_and_wrench: Looking for a few CNC Plasma, Laser, and Router users willing to help test something I’ve been building.
Like a lot of you, I’ve collected thousands of SVG files over the years. I got tired of digging through folder after folder every time someone asked, “Can you make this?”
So instead of complaining about it… I built a solution for my own shop.
Introducing the Valley Oak Customs Design Manager (Private Preview).
Current features include:
• Fast thumbnail browsing of large SVG libraries
• Search by file name, folders, tags, notes, and status
• Favorites and Collections
• Design notes and cut/testing notes
• Material recommendations
• Double-click to open directly in Inkscape
• Built by a CNC shop owner, for CNC shop owners
The goal isn’t to replace Inkscape or SheetCam. It’s simply to make finding and organizing your designs faster so you can spend more time cutting and less time searching.
I’ve been using it daily in my own shop, and it’s finally at the point where I’d love some honest feedback from other makers before I keep adding features.
If you’d like to try it, you can download the current private preview here:
Download:
https://drive.google.com/file/d/1mOCnGymmuNvhq7Xgs3sNmTA8nGEjUT6q/view?usp=drive_link
A couple of notes:
  • Windows desktop application only.
  • This is an early private preview.
  • It includes an easy way to send feedback directly from inside the app.
  • I’m looking for real-world suggestions just as much as bug reports.
If you decide to give it a try, I’d really appreciate hearing what you like, what you don’t, and what would make it more useful in your own shop.
Thanks!
— Ian
Valley Oak Customs
Update: Thanks to everyone’s feedback, version 0.9.5.7 now includes native DXF thumbnail generation. It can render DXF previews even when no matching SVG exists, while leaving the original files untouched.
can you give a few names of who you got feed back from?
Not from here yet, It was something I noticed while building it. I have also have posted it on a couple Facebook groups and people were comparing it to a app called Everything.
gotcha thanks
Have you tried it yet? Would love to hear what you think.
no but will give it some thought.
Been using the last few weeks and made some changes, see below.
New version available below
WHAT IS NEW IN v0.9.5.14
  • SVG previews now measure the actual artwork instead of relying only on the document page declared inside the SVG.
  • Designs whose artwork lies outside an incorrect 8.5 x 11 page, or another incorrectly sized page, are automatically fitted and centered in previews.
  • Testers do not need Inkscape or need to resize every SVG document page manually.
  • Preview fitting happens only in memory. Design Manager never rewrites or modifies the original SVG file.
  • SVG fitting is performed lazily in small batches so large libraries remain responsive.
  • If an unusual SVG cannot be measured safely, Design Manager falls back gracefully instead of changing the file or stopping the application.
    RECENT IMPROVEMENTS
  • Settings displays Design Library Folders, including Add Folder and Remove controls.
  • Multiple CNC design locations can be indexed at the same time.
  • Removing a folder from Design Manager removes it only from the index. It does not delete the folder or any CNC files.
  • Hovering over the selected design preview on the right opens a larger inspection view.
  • Both the small and large previews contain unusually wide or tall artwork within their frames.
  • The brief startup splash screen was removed so the application opens directly into the design library.
    CURRENT FEATURES
  • Browse and search SVG, SheetCam JOB, DXF, PNG, JPG, JPEG, and WebP files across multiple design-library folders.
  • Generate native previews directly from common DXF drawing geometry.
  • Produce best-effort partial DXF previews or a safe generic fallback for unusual entities without crashing.
  • Match SheetCam preview exports named design.job.png, design.job.jpg, design.job.jpeg, or design.job.webp to the correct JOB file.
  • Organize designs with favorites, tags, notes, status, collections, dimensions, material recommendations, and cut/testing notes.
  • Rename, archive, recycle, and batch-manage selected design files with confirmation prompts.
  • Preserve user data outside the Program Files installation folder during upgrades and uninstall unless removal is explicitly requested.
  • Send feedback through Gmail or the tester’s normal email application.
Design Manager Update — Preview Studio + Customer Proofs
A lot has changed since my last update on v0.9.5.14.
The current private-preview build is now v0.9.5.18, and the biggest addition is a new Preview Studio built directly into Design Manager.
Preview Studio lets me take an SVG or DXF from the library and create a customer-ready PNG without touching the original design file.
New since the last forum update:
  • Apply a steel/material texture to the artwork
  • Use a customer or shop photo as the background
  • Fit or fill the background image
  • Add a realistic raised-sign/drop shadow
  • Create filled-cutout and negative-plate style previews
  • Export PNGs in several useful output sizes
  • Add optional shop branding/watermarks
  • Use your own shop logo — nothing is hard-coded to Valley Oak Customs
  • Add an optional PROOF label
  • Add customer/job text for approval images
  • Control branding position, size, and opacity
  • Preview Studio works with both SVG and DXF files
  • Original SVG/DXF files remain unchanged
  • Preview and branding settings are remembered between sessions
DXF support is still best-effort when a file contains complex/open contours. As Drawn / Cut Lines works reliably, while filled previews work best with clean closed geometry. SVGs with proper closed shapes remain the most reliable source for polished filled customer renders.
The main Design Manager library features are still there too: multiple library folders, native DXF previews, SVG fitting, favorites, tags, notes, collections, status tracking, duplicate tools, archive/recycle-bin support, batch operations, and shop/material settings.
I’ve had a few other CNC users testing it now, and watching somebody else install it and immediately start making their own customer proofs has been pretty encouraging. :smiling_face_with_sunglasses:
I’m attaching a few screenshots showing:
  1. My C10 design library in the main browser
  2. Preview Studio creating a brushed-metal customer render
  3. The finished exported PNG
  4. The new customer approval / proof branding workflow
This is still a private preview, so feedback is absolutely welcome — especially anything that feels confusing, doesn’t work the way you expect, or would save you time in your own shop.
Current build: v0.9.5.18 — Windows x64
[Private preview download link]
Built by a CNC shop owner, for CNC shop owners.
