We have a new machine joining the Apollo family: the Apollo 4!
Check it out here!
Apollo 4 delivers a full 48" × 48" cutting area in a compact, fully enclosed fiber laser system. Get the speed, precision, and cut quality of industrial fiber laser technology without dedicating the floor space required by a full-size machine.
Handles a full 4’ × 8’ sheet. Apollo 4’s enclosure lets you load and handle a 4’ × 8’ sheet of material. The material pass-through feature allows larger stock to extend through the enclosure (front and/or back), giving you more options without moving up to a larger machine.
Easy access, built-in safety. Removable enclosure doors make loading material, retrieving parts, and accessing the work area quick and easy, while integrated safety interlocks ensure the enclosure is secured before cutting begins.
Industrial components throughout. A 1500W Max Photonics fiber source, RayTools cutting head, and 3-axis full closed-loop drive system deliver the performance and reliability you expect from an industrial machine.
Familiar, powerful software. Bring your DXF file right to the machine on USB, a shared drive, or a network location. LaserCAM works seamlessly with LaserControl, and if you’ve used FireControl, you’ll feel right at home. LaserControl gives you full control of every parameter while staying simple and intuitive.
Important: Apollo 4 requires two dedicated 240V circuits (30A for the laser system and 20A for the chiller) and a 10" exhaust connection. Please confirm your shop is ready before your machine arrives.
Specifications:
- Cutting Area: 48" × 48" (4’ × 8’ sheet capable with pass-through)
- Laser Power: 1500W Fiber Laser by Max Photonics
- Max Material Capability: Steel 3/8" (sever 1/2"), Stainless Steel 7/32", Aluminum 3/16", Brass 1/8"
- Positioning Accuracy: ±0.002" per 12", 0.0005" index
- Maximum Jog Speed: 1,350 IPM
- Z-Axis Clearance: 2.25"
- Cooling: Water-cooled, CWFL1500 by S&A
- Exhaust: 10" exhaust port
- Shop Power: Laser System 240V, 30A / Chiller 240V, 20A
- Software and Controls: LaserControl software, 32-bit integrated electronics, touchscreen and PC
- Safety: Enclosure with removable panels and door switches, optional camera system, optional doors with glass
Engineered in Texas. Assembled in Texas. Supported in Texas. Our team offers parts, fast shipping, consumables, warranty support, and technical support by phone and email. Have a question? Call or email, we’re here to help.
