Hey maybe you guys will know what i did wrong! I made a drawing in inkscape saved it as an SVG. brought it into fusion to what i assume is the setup and it is only about 4 inches should be about 14 inches! what did i do wrong? this is my first attempt at this and not sure i even know the correct steps. thanks Joe
That’s often a units conversion issue. What are your units in InkScape (Document Properties) set to and are they the same as the units in Fusion? If all else fails, add a square of known dimensions in the InkScape drawing so that, when you import to Fusion, you can either scale to make it match or measure and derive the appropriate scaling factor to apply during import into Fusion.
thanks ill try that.
