I create a drawing in inkscape, save it as a dfx as I have been.
I click import drawing on the file in sheetcam and I dont see it anywhere in sheetcam. I have zoomed out to try to find it but no luck. Thanks in advance!!
so SVG is by far a better file format when working with artistic things…
there is a big differance in the node count when talking about SVG and DXF.
a DXF curve is actually made up of multiple/hundreds of short lines creating nodes…
A SVG file is a mathematical formula between points…
here is an example of the differance
so instaed of processing 4 nodes your gcode will be a lot larger and mor complex with DXF.
DXF is great for technical precise parts to be cut…I use it all the time for that…but I prefer SVG for ease of modification…and for processing.
