Ok was just wondering. We want to see Sparks fly!!
YAAAAEEEEEE!!! Thank you guys so much. It Worked. Now to try a cut.
OK one more question. As I load a file and hit enter, it says “Validating Program. Pleas Wait…” It is stuck on this. What might I have done wrong?
It means your post processor was likely not correct when you created the program.
Is there a way to view the setup with out going through a complete file from start to finish? Fusion 360.
I’m not sure if there is in fire control but you might be able to download a *.NC viewer and look over the document.
No matter whether you’re using sheet camera Fusion 360 you’re going to have to install a post processor.
Search post processor in the magnifying glass or go back to the main site under support and there should be quite a bit info on getting that bit of programming installed.
