After importing a dxf file into Fusion, setting up plasma cut paths etc, saves as .tap file however when i open g-code in mach3 the drawing is incomplete. It just seems to miss have of the drawing in mach3. Any ideas of where to start? I checked the drawing but seems fine, what am i missing?
Are you running the licensed copy of Mach or the demo? If it’s a demo then you’re limited to 500 lines which isn’t a lot.
It will say Demo in the top title bar or your name if it’s licensed.
Bingo! Thats it. Strange Since I paid for the full license. I’ll have to see why it’s didn’t load the full licensed version. Thanks James
You have to install the license key. If you bought it from langmuir, they send you a coupon code you use at the mach3 website to purchase it for zero dollars, then they email you a license key that you have to install
