Improper uploading of gcode?
I’ve already cut a few projects but when I tried one today a complete new file that I loaded from Inkscape then converted to svg and uploaded to fusion 360.i went through all the processes did a cam setup and ran all the toolpath and even previewed the toolpath .did all the post process but when I upload the gcode in mach3 it only shows a partial prts and when I run it with the cutter off it only does a partial part…any help here would be greatly appreciated
Unless you have a license, Mach3 demo is good for 500 lines of code. Checked your lines of code?
I paid the $175 for the license but i dont think I downloaded the right mach3 because it still says demo up top …its a 7’x4’ ford logo shouldn’t be an issue with line code
Did you download the .lic file and place it into the Mach3 folder on your C drive? Even that small of a model could invariably have more than 500 lines, I’d check it in Mach3 with the Gcode file loaded.
I don’t think it’s a line issue because I’m the picture of what’s supposed to be cut out in the top right corner of Mach 3 all it shows is the top of the F for Ford
And where do I find the file for my full version ?
Here is a video we created that covers the process: https://www.youtube.com/watch?v=GOh-_DSXisc
That was the issue thanks guys!
If i purchase the full version on one laptop is it tied to that laptop or can i then transfer it to another laptop? Wife has taken over mine so i will be ordering a new one.
Yes as long as you have the copy of your license file you should be able to use it on multiple computers.
Thanks! Now i just have to figure out how to buy it for the $175 from Langmuir insteat of $200 from Mach.
http://www.machsupport.com/shop/mach3/
How long does the license last for? Do I have to buy/renew yearly? thanks
The Mach 3 license lasts forever, it is not a yearly subscription.
Can I buy it directly from you guys? What’s the cost?
