Importing images
Is the image outlined in green if it is you need to select all and hit the fix/unfix command
It is not. I’m also having trouble with learning how to scale down the image size. Example would be uploaded a silhouette image from google and it’s 300” tall by 250” wide how do I shrink that? This is my first time using any cad program so any info is greatly appreciated
Take the size you want ÷ by size you have. One direction only scale by that #.
Where do I select that option?
When in model > sketch > sketch scale.
Scalable vector graphic. svg
Best way to go
I’m noticing that once I import a image from Inkscape to fusion, that the image won’t scale. Anyone know why?
Is it green if so highlight the entire drawing and right click and select fix/unfix
That did it! Thanks man
No problem I need help on minor hiccups what this forum is for
