When I import dxf files I created in another program the file loses its smooth curves. Is there a way to fix this? Is there a better program that will transfer with a higher resolution?
What program are you creating this file in? And you have the choice of exporting an SVG instead of a DXF There’s been quite a few iterations of the DXF file extension and some don’t translate nicely. Do you have an example file of the DXF that is causing your issues?
I’m using vinyl master, my program I use for a vinyl plotter. I figured out a way that works. Instead of importing the file in dxf I tried doing it in svg. Works perfect.
