I recently replaced my Razorweld 45 with a Powermax 65.
What does the percentage in the cut chart refer to?
Any help is greatly appreciated!
Probably duty cycle
The percentage in the cut chart you’re referring to is probably 250%, they typically like the pierce height 250% of the cut height.
Got it… thanks I see it now that I have looked at it with your advice.
welcome
yes.
0.125" * 120% = 0.15"
0.125" * 200% = 0.25"
it is a % difference of cut to pierce height.
Do you have a Powermax SYNC?
In the standard powermax manual most are closer to 250%
Yes, just plugged it in a couple days ago with our crossfire pro table. I am in the process of changing the tool settings in SheetCam so I don’t have to keep adjusting settings for various parts.
I have the original PowerMax 85 and I run an adapter so I can cut with SYNC consumables.
Maybe there’s someone out there with a SYNC who already has made a sheet cam to a library they can send out to you.
I have a bit of a SYNC to a library but it’s in fusion 360. And the cut chart for the SYNC adapter is a little bit different
