Hello, I have ordered a Crossfire XR table, order number 32,592 and my Hypertherm Powermax 65 arrived today. I know I need a cable for the table and plasma cutter to communicate. Can it be sourced from Langmuir or do I need to buy it from Hypertherm? I received a remote torch control cable and box. Can that cord ge modified to connect into the Crossfire XR? I’m trying to make sure I have everything I need for when the table arrives.
Thank you for this info. I’ll add that to my order.
I was in the same boat when I ordered mine, I had all sorts of stuff ordered beforehand so I could get to cutting right away. I knew I’d likely be moving my table, so I did some casters plus lots of plumbing etc. to be able to drain it. I also did some bar sink drains to drain faster & more easily.
Do you have a machine torch for your Hypertherm? And a machine torch holder (available from Langmuir)?
In the interest of having everything ready:
Do you have an air dryer?
What is the CFM of your air compressor?
Thanks for the info. I ordered my Hypertherm Powermax 65 with the machine torch. Since I’m buying the XR table, it already has a torch mount. My compressor puts out 16 CFM’s at 100 psi and I have a high quality air dryer that allows me to run my bead blast cabinet for hours without any moisture problems. I believe I have everything covered except for the cable, and deciding on what kind of water treatment I am going to run. I appreciate your reply and giving me a heads up.
