Hypertherm 65 air filter bowl
Alright, just purchase an older powermax 65 with the shielded air filter bowl that is missing and needs replaced.
Question 1: does anyone have a used one they would be willing to sell?
Question2: since i am using an air dryer anyways, is there a way to bypass the factory air filter since it will not be needed anyways…if i cannot find bowl replacement.
The newer hypertherm pm bowls do not fit the older models and i cannot seem to find the guarded bowl anywhere online.
Sure you can bypass the filter, just remember to put the pressure switch in line or it won’t work
You mean removing the pressure switch and installing it on a tee fitting when creating the bypass line?
Yea, that’s what I mean
Great, thx for the tip!
