The controller is shipped with isolator mounts, you don’t want controller box grounded to table. Is there continuity from controller to table? I would check for continuity at each end of on/off torch cable to make sure it is good.
Checked continuity and seems good. Just as I was about to send this message I jogged the machine all the way across the table and hit manual torch it fired
. I’m not sure what that did. Was able to run the test with no no issues and fires now.
Thank you for your help I’m sure I’ll be back with more questions
New and my first post.
Received my crossfire pro a few weeks ago. Set up and first cuts went fine after remembering to put machine torch consumables on my hand torch.
Not wanting to buy a machine torch and also wanting to use the hand torch without having to rewire everytime between hand and machine.
I decided to put a switch in the hand torch connector housing .Allowing me to flip a switch to choose between handheld and machine. Also no need to tie the hand torch trigger closed anymore.
See pics.
Feel I am correct in calling the switch a DPST?
Should have said hypertherm 45xp
DPDT - double pole, double throw
Stand corrected, it is as you say DPDT
