One of the hydraulic lines was finger tight and upon powering up the machine, pumped a bunch fluid out. Is there a specific fluid I need to use to refill?
I briefly searched through Langmuir’s main page assembly guide and there is NO reference to the type of Hydraulic Fluid use.
https://www.langmuirsystems.com/titan25t/assembly
I did find this note in the guide
" * Be sure to read and understand all MSDS safety data for any materials and fluids used in operating the Titan 25T"
I didn’t remember seeing MSDS packaged with our Titan for the fluids it was shipped with.
@langmuir-sam Can you provide us with a link to the MSDS of the fluid you are using in the Titan? then @Jody1 will be able to source an exact replacement and have the Material Safety Data Sheets.
The hydraulic fluid spec is listed in the operations manual specifications page.
ISO Grade 32.
Here is an example material safety data sheet for one company’s ISO Grade 32 hydraulic oil:
The information is the same for the hydraulic oil we use.
I see why i missed it with my quick keyword search. I was searching the term “fluid” not “oil”
https://www.langmuirsystems.com/titan25t/assembly#titan25t-manual-6
Good to know what you filled your machines with.
As it is always best practice to avoid mixing different fluids when topping topping off a tank. Even though it will likely work just fine if you do .
