Wanting to clarify the additions we’ve previously made to FireShare and the new ones just published today.
‘Cut Ready’ in the FireShare context means that the file has been post processed and transformed into cuttable Gcode without needing to use SheetCam or Fusion to create toolpaths. More info here: NEW: Download and Share Cut Ready G-Code on FireShare
On download, you can override the cut settings (Feed rate, and Pierce Delay) for your specific material and cutter.
In addition, as of today, If you are downloading a Cut Ready FireControl program from FireShare and it has been post processed with IHS (contains the probe sequences at the start of each cut loop) you now have the option to download the program without this IHS sequence allowing you to run it without issue on a standard Gen2 (FireControl) CrossFire.
I’ll be making a larger post about this feature shortly.
