So when I upload my file to fire control and try to turn it long ways it’s off my table and I can’t get it to where it’s on table can anyone help even if I turn it 90 degrees it’s still off table
You have to set work zero and point of origin. That will set it right. Move torch where you want to start. Then zero all axis. Hit point of origin button and chose the green box you want zero to be.
You can also select new origin position if you like to start lower left. GL
@Redbeardwelder19 Welcome to the forum
Have you set up your soft limits for home on your XR?
Home on the XR is the upper left where normally most people use the bottom left for the origin point.
New to this that worked i appreciate it!
