How to convert a dxf file to a .nc
Is it possible to convert a dxf file or other type file to a .nc file?
Everyone who runs one of these tables has to do it for most of the things they cut.
You need to use Fusion or Sheetcam to create cut paths and post process the DXF into an .nc (Fusion) or .tap (Sheetcam) file.
@kingdom
@ds690 said it pretty clearly…
you can convert just about any file into a (tap) or (nc) file…
Fusion will open a (dxf) file…then you can post process from there…same as sheetcam…
