I design, post, and upload to Firecontrol at which point I get a message:
"You have attempted to load a program that was posted with an out-of-date Post Processor, Please update your Post Processor to v1.6 Before posting new programs.
In the meantime, Firecontrol can convert this program to make it compatible for cutting now.
Select 'Convert & Save below go convert and then save your program"
It does create and save a new file that will load and allows me to cut but would like to get away from having this second step as well as 2 files for the same program.
Where do I find my outdated post processor and once located how do I update it to v1.6?
Keep in mind that which post processor you should be using depends of which version of the motion control board firmware you are using. MCB firmware v1.1ls matches up to post processor v1.5, and v1.2ls matches up to post processor v1.6. Once you have downloaded the post processor, you will need to replace the post processor that is installed into your CAM software.
