I have been trying to get my table going. I have the table jogging just fine in all axis. When I installed the limit switches and software I then tried to home the system. It only moves the z axis and runs it up to the top. No other movement
Reread the directions about installing 21.1.5 and resetting defaults. See below…
My machine is homing slowly, homing the incorrect direction, or trying to
home the Z-Axis.
You need to ‘Reset Defaults’ after your machine firmware has been updated. This ensures the
property homing settings are flashed to your machine controller. This Reset button is found at
the bottom of the Machine Settings Menu. This will reset your soft limits so note these down if
you set them previously.
Current directions are here
Thanks, I think the problem was my slow internet connection where the torch was. I put a longer USB on it where the computer could be in better range and repudiated the Machine then reset everything the same as before and low and behold everything worked like the instructions.
