Hobart Plasma Cutter Anyone
I was wondering if anyone was using a Hobart Airforce 40I Plasma Cutter on here?
I’ve got the Hobart 700i. Same machine. I believe the only difference is you have an upgraded torch
I use the Hobart 40i with my table.
I use Hobart 250ci with my desk. Amazing, with a good cutting torch.
What speed do you run at? I was trying to run what the book said and it was not working.
I upgraded to a Hypertherm when I got my Pro table but when I had my original table with the Hobart I followed the Hobart cut charts and never ran into any issues. Perhaps you have moisture in your air or need to put in new consumables?
Hi I just saw that used the 250 ci, I am wondering about the wiring? Could you post a pic or diagram of how you had it wired up? I don’t want to fry the motherboard if something is not right.
May i inquire as to how you did you tool setup in fusion 360… i.e. the values used. I have the airforce 700i as well
