I’ve had the CrossFire PRO for the last few months, everything working great, used it extensively to cut out lots of parts.
Now it sat idle for about the last 2 weeks and I am trying to use it and I cannot get Firecontrol and my laptop to communicate. I am running Windows 8 and this laptop is dedicated to the CrossFire (i.e. it also hasnt been used/no new installations, updates etc. the last 2 weeks.) I have the CrossFire Pro w/THC and the latest version of FireControl.
When I plug in the usb to my laptop the green light comes on the control box and I can hear the high pitched humming of the motors/box change but there is no little chime on my PC to indicate a device plugged in (unsure if it usually does it for the crossfire?). I’ve tried all three ports on my laptop, ive also plugged in a mouse on all three to make sure they all work; all good. I’ve also tried using a different usb cord with the same ends on it; no difference. And yes I tried restarting my computer too.
I attempted to reinstall the drivers by following this guide https://assets.langmuirsystems.com/firecontrol/drivers/Windows7-8_ManualDriverInstall.pdf. However “Crossfire CNC” does not show up in the list, the “Other devices” tab isn’t even there… I also checked under “Unirversal Serial Bus controllers” at the bottom since I read a few other posts where it showed up under there… I did however uninstall and reinstall FireControl USB THC Driver using the wizard.
I will reiterate that I had everything working great before; I had to manually install the drivers when I first got it a few months ago but otherwise at the time my laptop and Firecontrol worked as it should. And absolutely nothing has changed with my setup since.
I am not super computer savvy and am really hoping there is a super simple solution that I am missing! I’ve been just beating my head against the wall the past few hours with this!
Thanks in advance guys!
