Help with fusion 360
Nicely done, sir. Nicely done!
Tin Whisperer is usually spot on! The easiest way I can explain the issue you’ve gotten help with and figured out is that you were telling Fusion to drill a 1/4" hole with a 1/2" drill bit. Doesn’t/cannot work. So, when you’re dealing with very small cuts, that is usually the challenge. But remember, Fusion isn’t the issue. If it generated a tool path that small and let you continue, the plasma torch will just blow out that metal and you’ll have a terrible product. Also, know that you can set up multiple 2D Profiles in one Setup in Fusion. This allows you to customize the settings (feed rate, lead-in/lead-out, etc for different parts of the design.
