Ok. Getting all set up to cut and my machine will only job in the positive directions. Both arrow keys are moving the head in the positive direction on both axis.
UGGGGG!!! Its not binding. When I hit return to zero it goes in the other direction obviously a setting or software glitch. Tried to run a g-code to set if that would work and I get an error
Check to make sure that both motor connectors are securely plugged in and the two screws for each connector are tight.
Solved! I changed my homing limit settings from a suggestion here. It didn’t really work. But when I changed everything back…bam! It worked! But, the problem was I didn’t put the minus back in when I reset everything. Added it back… all fixed. Thanks guys.
