Hey guys, so I just purchased a Powermax 45 xp with the machine torch and CPC port. I’m trying to figure out what I need to do now to get it hooked up to the table. What exactly do I need to do to get this going?
I was wondering if you ever figured it out and if you did how you wired it up. Thanks
Hi,
So what I ended up having to do at first was splice into the torch wires inside the Powermax then I routed the wires our by the little air inlet on the back of the Powermax box. Eventually I took the wire and cut the splice end off and added pin ends that fit into the cpc port( I believe it was pin 3 and 7) but I’d double check before doing that. Hopefully this helped you out. Let me know if you need anything.
