Help Once the plasma pierced the metal on the first cut it quits moving and the torch on/off flashes yellow and dwell is flashing
Which plasma cutter are you using?
Razorweld cut 45…
Make sure thc control on mach is off, if it’s on, its waiting for an arc ok signal
