Help! FireControl keeps disconnecting
Need a little help here. Been running my XR for over a year now with no real issues. I have an Everlast 82i hooked up to it. Couple days ago I started having issues with Firecontrol disconnecting in the middle of a cut. Disconnects and my torch stays firing so I have to hit the E stop. Did some troubleshooting, disconnected the charger from my laptop, usb has a ferrite choke, I always ground directly to material. Not sure what’s causing to disconnect as I’ve never had an issue and haven’t changed anything. Any help or guidance would be greatly appreciated!
Having the same problem with Crossfire XR, FireControl and 82i with cnc plug
