@TinWhisperer, well let me see where to start…
starting yesterday I was attempting to cut some targets. They are out of 1/2 mild steel, 8" in diameter, leveraging the cut settings from hypertherm reference materials:
- Torch Cutting Height 0.06
- Initial Arch Start .18 arch
- Cutting Speed 30ipm (adjusted to 20ipm based on not cutting through)
- Pierce Delay 1.2
- Amperage at 65amps (today added 5amps just gits and shiggles)
- Airflow at 60psi (while running)
Now the odd part is it cuts in a straight line like a champ (yesterday). but today it won’t cut anything due to errors in arch or THC issues. It also cut a nice hole out in a portion of the part. Just not the entire part. It’s not making any sense.
Now where are we, oh yes, today I go out and I think ok, back to basics.
*Check air source for water, check good
- Check all the inline filters (oh which I have two, 1- on the tank, and the OEM one on the hypertherm. check good
- Check consumables, check good
- Check ground, check good
- Check program, check good
- Check water level in table, check good,
- Check myself before i wreck myself, oh wait, no no that’s the 90’s…
Fire up the system, run the part, get the no spark errors messages in firecontrol, touch height too high, or ground no good, or THC sense’s no voltage, arg! Run the THC testing in Firecontrol (firmware 1.11XR) and check good.
I start all over again and reboot the entire thing…no joy, 4 hours wasted and go to grab a beer, because that at this point. That is way more productive than what I am getting out of the machine.
Straight cut to ensure it actually is the right setup. (yesterday)
Target Failed cut 3rd time overlapping to not waste more material ( and, wasting materials ugh) and the actual target or what should be a target. Yet it is because it decides to not cut all the way through in some spots and not in others, etc, etc. (nice edges on the hole it actually cut through on though…insult to injury.
Consumables post cutting:
Drank beer, opened the porn box and fired off a support request to Langmuir, came to the forum to read and search more on what I am having issues with. Found out that I have support since it’s and XR. So plan on calling and talking with them tomorrow, if that bring’s not joy. I will look to sell this off and find another solution.
Time for another beer…oh and all Hypertherm consumables, OEM baby!
