Hello , just got my machine assembled. The jog function was working great yesterday , now today I can’t use the arrow keys and can only get it to jog at a snail’s pace with the on screen controller. I’m sure it’s something stupid but I can’t figure it out. Also it won’t run the g code now . I have a video if needed.thank you for any advice
There should be a setting for jog speed. Can’t help you much more than that as I don’t use mach3
Hit the tab key. Adjust the %
How did u fix your problem I too am having the same issue I have ajusted the jog speed with no change
Hi @stephensron, can you elaborate on the issue? Is it that the arrow keys don’t jog the machine any more?
When I was opening up mach3 it wasn’t loading the langmuir profile . I reinstalled everything and it works fine now. Hope that helps.
The arrow keys will not move either axis
When you open mach 3 you see the langmuir profile right?
yes I do see Langmuir profile
Follow this. Took 5 minutes
Hi,
Did you get your issue resolved? I have the profile loaded. It worked fine once and tried another file right after and the table stop jogging with the computer keys. Could this be an issue with the USB port on the table? I’m not receiving any errors so not sure.
Bev
