smoker plates.nc (3.4 KB)
Maybe a linking constraint issue?
One or more passes is discarded due to linking constraints? SOLVED - #2 by TinWhisperer
Post a Fusion *.F3D file if possible
20 smoker plates.f3d (179.1 KB)
can the plates ( half circles ) be moved apart so they aren’t cutting over each other ?
Kerf is set to 1" in the tool . set it to .055 or whichever your charts says
Based on this picture alone, you can tell your kerf width is huge.
The blue line is the cut path your torch will travel, which is set by you and the kerf width you’ve entered.
20 smoker plates tin mod.f3d (179.1 KB)
Attached is a modified file
So thankful for your help man - I have been stuck for hours… Clearly new to this … so appreciate your help
