Harbor freight made it easy to connect to the arc voltage.
Yep. I did it exactly like you’ve done. Had an initial problem with low cutting voltage using the THC test but after verifying my voltage on the torch and re-plugging in the banana plugs everything started working properly. Did a test cut on a scrape piece of 1/16 thick sheet and it was the cleanest I’ve ever cut. And O by the way the metal was as rusty as could be. Amps at 20 and 40ipm.
