I tried to get David to start this topic. A number of people on this forum, other than me, should be writing this.
Today, David made a statement about what he should do but doesn’t always do it. I thought that many of you have some tip(s) that you would have given yourself in the first year of learning your craft. I made up a list just to get started but am hopeful that others will give input. And like Knick has said, ranking the items would be a great idea. Perhaps none of my items will even end up in the final list of “best Good Habits.”
If need be, we might have three list: Good, Bad and Humor.
Here goes:
Advice I would give myself, if I were just learning CNC Plasma cutting with the Langmuir system.
Be sure to have the torch, work zero and program origin all at the same location before starting your cut.
When cutting an expensive piece, consider a manual pierce at work zero in case you need to recover the cut program. (Paraphrased from David @DS690 - sorry/not sorry for putting you on the spot).
When picking the software you will use for CAD/design stay with one program long enough that you can make and modify a simple design. You should be able to vary the size, location and number of features without referring to notes or video before moving to the next CAD/design program. Now you have a benchmark to test another CAD/design program to see what feels intuitive for you. Pick the one that aligns more closely to your final goal. Stay with that one program until you have some sense of mastery before allowing yourself to question your decision. It is okay to change your mind after you master one program.
Cut out something fun when you first start, if you need to, but then get to business with improving the cut and nailing down your settings. Otherwise, you will be wasting a lot of metal and time.
Check that the air supply is on (and adequate) and work lead is attached to the metal before pressing “START.”
Don’t skimp on your consumables. Buy quality and check them like children on a playground. It is not “IF something will happen, but WHEN something will happen” when talking about children and consumables.
Buy everything that BigDaddy recommends. (Couldn’t help but adding this one.)
