Sorry not running Mac, but there should be a field in the Post Processor that indicates where the file will be saved. This is what mine looks like, yours should have something similar…
The advice you’re getting here is correct, your G-codes are being generated into the location that is shown in the output folder section of the post processing menu. Keep in mind that you can also change the output folder, meaning that you can choose the location where your G-codes will appear once they are generated.
Thanks you to everyone for your help. (Even you non-mac cavemen ) But it took a reinstall of the application. Now , I get the option to set the location for the output file. And all is good.
Really liking the new Firecontrol. Along with the THC & Machine Torch I also added. The table is working flawlessly!
