Hello,
I am at the point in my CF Pro assembly of mounting the X axis motor mount and the bearing mount. The screw holes on the motor mount and bearing mount are the same distance apart, but the holes on one side of the gantry are to far apart. Am I doing something wrong or is this an equipment mistake?
Make sure you have the correct mounts on the correct AXIS.
SOLVED
Thanks, The X axis bearing mount was packaged in the bag containing the Y axis mounts.
can you add SOLVED to the title so it’s visible. Thanks
