Hi,
I installed the XL kit but doing so had to remove the bolts on the gantry here:
Following the writeup I still had issues getting the new longer tubes to slide into the gantry and make the correct bearing contacts. I fixed all the blocks and did the alignment and now the bearings look to be seated correctly.
Now that I have it done I have this issue:
Note that the arm is slightly higher about .85 deg elevated from the gantry. Here it is in relation to the slats:
I could move the casters around and try to get it level but I don’t think thats the issue. Anyone have any suggestions on how best to get the gantry level?
Thanks!
