i am working on installing an upgrade kit and i keep running into an error. i thought it might be to do with the lead ins and lead out, or my plunge rate being to slow. attached is the error im getting, as well as the gcode file. any help is appreciated! i am using sheetcam to make my gcode not fusion.
art-022 bigfoot light cover single.tap (41.1 KB)
Do you currently have a powered Z-axis (THC / IHS)?
yes i do have the powered z axis. i bought the whole upgrade kit
so i downloaded a cut ready file from fireshare and the gcode works without issue. itmust be a setting in my sheetcam
If i run my lead ins as perpendicular and not arc the problem goes away. I tried all three styles, arc and tangent both cause the issue.
Although i have the machine running now by using perpendicular lead ins. I still want to figure out the root cause of the issue for future users. could the issue be stemming from using inches in my post processor rather than metric? i am comparing gcode from an xr machine that i have been using while mine is down and the xr is running in metric. i will update back later after i test exporting in metric.
