So so… This is my first post in the forums. CCrossfire Pro setup, straight line cuts are perfect using a razor weld cut 45.
Using fusion I’ve got a 39 mm star program done and when I send it to the fire control system I get this error. I can download a cut ready program from the fire share and it cuts it perfectly. It looks as though the fusion 360 is trying to do it in GRBL.
Any help appointment in the right direction would be fantastic! Thank you.
Thank you for the help. I hate the sound ignorant. I have downloaded the latest post-processor into my downloads but I have absolutely no idea how to install that into fire control.
The post-processor is used by Fusion or SheetCAM to make the gcode in the format that FireControl is expecting. Since you are using Fusion, the link Tom gave you will help explain where that comes into the process.
