Well since Autodesk has taken the ability to print a pdf of a sketch, I’ve found a new way to print drawings. I just right click on my sketch and save as dxf and then import it into inkscape. I select read from file for method of scaling, manual scale factor of 1.0 and text scale factor of 1.0 then click ok. A new window opens and i select include svg image as editable objects in current file. An voila, you have a scaled image you can edit or print.
A program I use a lot is GREENSHOT. https://getgreenshot.org/
I use this to capture a lot of pics. it will capture anything on your screen.
