Fusion issue with toolpath and contour selection
Having issues with tool path always get a warning of: one or more passes were discarded due to linking constraints. I am unable on some contour selection to change the cut from inside to outside or outside to inside. Really could use some help want to cut something on this thing. I am using a project file from Langmuir
This typically occurs for one of two reasons:
  1. The kerf width is larger than the feature being cut. An example would be a slot that is .050" wide when your programmed kerf width is .060".
  2. The lead-ins and lead-outs do not fit. An example would be an 1/4" hole using a 1/4" long lead in. There is not way to make the lead in fit within the hole.
I created a new design using an existing DXF file i had. It loaded and i could select the contours and followed all the options shown in the video but when i click OK it tells me no tool path. Not sure why.
